rob is it possible to buy new seals for the metal strip that fits across the base of the windscreen :?
well is it :?
lol…I did look , but forgot to post a reply…
If you are referring to the rubber strip that runs along the bottom of the window and attaches to the black scuttle trim, then no you have to buy the scuttle trim to get a new rubber seal.
Its a very wide item and i would have to bring it into the UK with one of my Coffin shipments ( IE: a big Fuck Off Box we bring in twice a year for big fragile items like Door top trims)
We then have the problem of shipping a really fragile item around the UK
I will look into it and get back to you.
cheers rob it was just the rubber seal i was looking for as i have 3 of these scuttle panels. i was going to make a reverse mould of 1 and cast it in carbon then slide the rubber seal on.
Cool, the gasket looks like it is a preformed item too, special made for the item.
Shame
yea i noticed that aswell. i could attempt to make it including the shape of the seal and use epoxt resin so it flexes against the winscreen. ill give it a try,need to wait for the warmer weather tho :lol:
