I have a set of 316 Stainless Steel Brake Pistons available.
These are brand new, ready to install in the front calipers of a GTO/3000GT
Stainless Steel is a great insulator, and will reduce the amount of heat transferred from the brake pads to the pistons, and hence the brake fluid. This will reduce the temperature of the fluid at the calipers, and reduce the amount of brake fade.
316 Stainless Steel will not corrode like the standard pistons, so reducing the possibility of the pistons sticking, and also reducing the possibility of corroded pistons damaging the seals.
These pistons are a direct replacement for the standard items, in either the 296mm or 314mm calipers.
£120 incl P&P within UK
Ps. I will post some pics in a bit
