I have a pair of factory turbos from my GTO that were removed in April. It has done approx 80-100k miles mostly on standard boost (I ran them at 12-16 psi for a couple of weeks before I upgraded to my DR750 turbos), would make good spares or core swap for upgrades.
EDIT: Some studs are missing so you need to swap them from another turbo or purchase new ones. Shaft play on both turbos approx 1mm but I will double check again.
£110 posted
Anh
