Need some minor bits if poss,
1 injector seat seal (injector to lower plunum bit)
1 rear turbo IC oil ring (rubber bit on the hard pipe connecting to rear tub)
not sure if this is a doable, but the seal on the oil pressure sensor is blowing oil, can this be replaced, or is it a full new sensor ?
Also im pm’ing re short shifter
