Spares and tuning stuff
All are to suit a MK1 twin turbo-may fit MK2
Hella upgrade headlights with naughty110/80 bulbs £75 posted-sold
ECU overhauled by ecu doctor in 2009 MD159964 save £50 only £200 posted.-sold
Braided clutch line un used £15 posted-prov sold
Polished front fuel rail £12 posted sold
MK 2 upgraded lifters bought on here only 3000mls with tool to fit £100 posted-sold
Custom bonnet vents good nick but would need rubbing down to suit your colour (silver now, peeling one edge) £75-sold
MAFT Gen11 translsator with GM 80mm maf and harness,+filter, will run larger injectors,adjust fuel,remove restictive stock maf -made big difference when I de catted as well £160.-sold
Can e mail pics as I havent yet mastered posting pics on here!
Mike r
other bits
coil pack £25 delivered-sold
electric aerial mast as sold by evil Rob-new but has grease on toothed belt where I was going to fit but failed! £12 posted
Uprated fuel rail jumper £20 posted=sold
Mixed box of ecus-(not engine) /relays/fuse holder £30 sent-sold
Set of ecs struts,one front one has small mark on rod,no leaks but electrically unknown,1 pair of grooved std rear discs,been painted silver with some rust starting but should be ok,front n/s hub/pair of std front calipers ,1 good 1 needs o/h std fuel pump .£80 the lot but must be collected Cardiff%between%
Hi Mike
You have PM Re Clutch Line
PM re: fuel rail
Staff
