Good morning
Just wondering what are the chances you have a speedo sensor for a 91 tt import please see image as reference
You could put it up in the wanted section, I purchased a second hand one and hoping that it works as my last one was crazy ! Wonât know for a while as the engine isnât in at the moment
Hi ReeseThanks for your reply, I have managed to find one from someone in China with same part number so hopefully itâs a good one and works.3 weeks wait and countingCheers again Dave
If this fall through I have one spare,
Is it deffo at fault as I got another and it was the speed converter at fault.
Cheers stevie
Will be in touch if no show of part
Have had check at the garage and they said so.
Dave.
@davesoper64 I hope You wouldnât mine me borrowing Your post Dave but Iâve noticed today my speed needle doing the Greek Dancing , is moving as it should when the car starts moving at about 10 - 20 miles and it shoots up to over 100 miles when accelerating and then drops down again when decelerate. I assume the sensor got faulty or it got disturbed when my clutch was replaced a month ago. Any ideas Guys ? If the problem is the sensor I will be needing one. Cheers
No worries mate but I have to hold my hand up and say @stevie was right in a reply to my original post it wasnât the speed sensor but the little speed converter that sits at the back of the clock cluster (kph to mph)
Hope this helps in anywayđ
Sounds like the chip to me too, mine did this @spiros
I thought was more likely to be the sensor because of the work on the transmission ! Do I need another chip then , need to take the instrument panel out and have a look !
I would say yes with what you have said is happening
Speedo speedometer converter chip E-SVA IVA KMH to MPH CARTEK CK-UN-09
This is what I got on ebay .
I need to see what Iâve got now, is this a decent one Dave ? It says âfor any vehicle with automatic transmissionâ ?
Yep this is fine itâs the same one that I had to replace
All you you have to do is tell what type of car itâs for when you buy and they send you the correct one with good fitting instructions đ
Speedo is working fine againâŚno wasnât my imagination
Must have been your heavy right foot
Itâs the sun shine everyone happyâ:smiley:
You may be right Guys I had my wellies on
Back to my problem , the car was locked up for few weeks and didnât have the chance to look in to the ( suspected speed converter ) problem .
Today took her out for a run and noticed that the needle nor the counter wasnât working , continued driving and both needle and odometer started working again .
The needle looked that it was working as normal till I hit about 80 miles and then it was going mental to the end of the clock , also when accelerating fast from slow speed it doesnât like it and jumps up to 100 + .
The odd think though is that the miles to my destination and back is 52 miles but the odometer has clocked 147 miles
Do You Guys still think is the speed converter and not the sensor ??? Cheers
I have my old sensor which I donât think was the issue if you wanted to test that to see if itâs any different?
Thanks for the offer Reece, Iâll let You know !
