gto66
#1
Start Button.
I am trying to install a start button, i got as far as installing the button on the ash tray.
I have taken of the surround on the steering coloum. we put a amp tester on to find the constant 12v but with no luck.
Has anyone installed a start button? i would like some advise on what wire to splice into i have a 1992 twin turbo.
Pleas HELP
i have, im assuming you have found the connector for the ignition switch? think its blue, then basically you need to:
snip the yellow and black wire
Splice into the big red wire
connect both to your switch
You could just splice into the yel/blk wire and keep your key start too
gto66
#3
Thanks for that. I will give that ago.
