Hi guys,
Got home today and for some reason I’m clutch is sticking at about mid way??? I popped it back up with my foot and pumped it and it’s fine but then when I tried to park it, it did it again??
Any ideas what it might be?
Richard
Hi guys,
Richard
Check the slave cylinder if it’s leaking hydraulic on top of gearbox,check hydraulic level in the reservoir
This post would attract more attention in the relevant technical section
This section is for newbie introductions
Hi Richard. As Craig said try popping this in the tech sections and it will get a better response.
It definitely sounds like you have air in the hydraulic lines. Most likely a leak from the slave or master cylinder. As Jerry said check for signs of fluid leak around both to find out which one. If nothing there then trace the clutch lines all the way along and see if any of them are wet.
Hi max,
The only place I can find any leaking is on one of the hoses.
Any idea where I can get a replacement for this one ?
I keep them in stock in 3 colours
http://evilempireperformance.co.uk/gto-3000gt-shop/index.php?main_page=index&cPath=22_144_147
