Twin Turbo Crankshaft Timing Gear
Hi Rob,
Marc Sassoon tells me that you might have a spare crankshaft timing gear (ie the toothed pulley that drives the timing belt). If so, would you sell it to me and for how much? :slight_smile:
Edited to say, also after a price for a water pump please.
Thanks, Robert.
Hi Rob,
I have Genuine Mitsubishi Water Pumps in stock @ £95.00.
The Timing Gear Marc mentioned has unfortunatly has been used.
But i may have another, i will loook for you this afternoon.
Give me a call this evening on 07891-606913 and i will let you know if i found it.
[quote]Hi Rob,
Cheers Rob[/quote]
Hi Rob,
Thanks for the reply. I’ll give you a call early evening.
Robert.
Hi Rob,
I tried calling you but no reply. Did you find a timing wheel?
Cheers, Robert.
Hi Rob,
Sorry cannnot help you this time, I could have sworn i had 4 knocking around.
[quote]Hi Rob,
Cheers Rob[/quote]
Thanks for looking anyway.
