For sale i have a set of extremely rare Unorthodox racing lightweight cam gears for the 6G72 engine. These cam gears are extremely rare as they are no longer made and not may people wish to part with them.
They are regarded as the best cam gears to ever come to the market for the 3000GT/GTO. These will fit all DOHC 6G72 motors 3000GT/GTO/STEALTH. These gears will not slip unlike some other brands on the market today.
These cam gears i have for sale are used with only the rear CAS cam showing any signs of wear, it has been rubbing on the inside of the cover and had has a few marks from what looks like a tool slip. the remaining 3 are in perfect condition.
Some info taken from an old advertisement:
Our Ultra Series gears are the pinnacle of adjustable cam gear technology. All the right engineering, giving you pure reliable performance! Our gears set the industry standard for craftsmanship. Each gear is CAD designed and CNC from lightweight 6061-T6 billet aluminum. Each gear is adjustable in one degree increments to a maximum of +/- 10º (advance/retard). Any adjustment of the gear/s more than 10 degrees is useless, you may as well just skip a tooth during installation! Engine damage can happen to some cars after as little as 4 degrees. The engraved timing marks are accurate to within one (1) minute of a degree 60 minutes in a degree)! There is no such thing as having to send our gears to machine shop to be re-indexed properly! Other aftermarket gears can be off by as much as 1 or 2 degree!
Tooth profiles are also extremely important when machining a gear. Long term reliability of the teeth and timing belt are directly related to the shape of the tooth profile. Our tooth profile matches the OEM specification exactly for each gear we make. The outer toothed section of our gears are hard anodized, to prevent any wear from the timing belt. We also chose the black finish because of the great contrast against our engraved timing marks.
HP / torque gains on stock or aftermarket cams
5-bolt pattern for a lifetime of worry-free adjustment
Easy to read timing marks, CNC engraved not painted or etched
Adjustable in one degree increments to a maximum of +/- 10º
Accurate to within 1 minute of a degree (60 minutes in a degree)
Gear tooth profile identical to OEM spec
Hard-Coat black anodized gear teeth
CAD designed & CNC machined from 6061-T6 billet aluminum
£250 delivered.
