I am putting an order together to place with you but would like to know if you have the rubber washer bottle seals for the pump and sensor? (I don’t actually need the sensor or pump)
Gavin
Gavin
Hi Gavin,
The washer bottle one is in stock.
The seal for the sensor is an integral moulded part and the sensor costs about 50-60 quid :shock: :shock: :shock: I will check for you
Thanks Rob
£50 / £60 quid for a seal is a bit steep. :lol:
Hopefully you can come up with something - silly me disturbed it when I removed it from the car hence the need for a new one.
Gavin
