Just been to look at a mk2 tt can someone explain why the rear aero has no motor section the spoilers the same but the curvede bottom section isnt there its bolted straight to the boot lid
hmm also i noticed theres no cruise control,inside the engine bay on the right hand side theres usuall 2 boxes that guys tend to cover with bling lids ones small and the other bigger with several pipes coming out of it,that ones awol
They all have cruise control as far as i know, so must of been removed. As for spoiler, maybe boot or spoiler was replaced due to damage or bad paintwork. I think the spoilers often fade/peel.
Jensen
just reading upon them now,apparently they have 11g tubs not 9’s or is that hear say,im sure the weight saving wont matter with my lardy posterior sat in it
MR were like 100g lighter or something silly, quite a few of us have them, still the full fat turbo car just with out all the crap. Mine had plastic headlights but hard to tell from the picture.
Most had although could be added as an extra
No 4ws
No abs
No active exhaust
No active suspension
No cruise control
Different throttle cable
No active aero
Unique MR badge lol
Which means there are minor differences on the wiring loom
MRs use the same Spring set up as n/a’s (could be wrong on that one)
There are a some other small differences as well but can’t remember them all like brake ducts and things.
If you were to sit an MR and a normal full fat TT next to each other, cosmetically, apart from the aero, they would look the same.
I have a tt MR 1997 with hoop spoiler and it’s fitted with 9b turbos as standard, if you check the turbo housings you should be able to tell very easily.
