I will have some ECU plugs tomorrow (all being well and they being the ones I asked for) Once I have these I’ll be able to make the cables up and ship them out for early next week.
The cost for each one will be a whole £3.50 which includes postage.
I’ll post tomorrow once I have the ECU plugs and get in touch with everyone by PM with payment details etc.
I have had the ECU plugs in today and guess what, they dont fit :x
They are the right shape / pins etc but the pitch is out by 0.5mm so they do not fit with the crimps in. I am sorting this out with the supplier to see if we can get something right but until this is sorted I can only do the cables with spades on.
Can I ask all still interested in a cable with spades for now to PM me.
I guess they aren’t the same as the ECU ones then… Have you tried TYCO/AMP that is where I sourced the E-manage and ECU Connectors from, never tried for the Diagnostic port connector…
Did you manage to get the part number? need any help in sourcing it?
Out of interest which chip are you using?
I went for the MAX233, needed fewer external components…
I tried Tyco for the plugs and they gave me a part number etc. I have some of these and it looks the same but the pin spacing is just slightly out so it wont fit. The shape etc is the same and looks ok. It even goes in a bit but then stops. Any assistance in the part numbers etc would be great. I’ll email over the info I have so far.
As for the cable spec, the one I use is very basic and does no use a chip, just a resistor and diode. I’ll email a spec over for you. This works in every case as well so can only see the need for the chip to boost the output signal.
Shall we take this ofline and deal over email etc as I cna attach bits etc. Once we get it sorted we can post up here again. I also have some ideas and bits (555’s etc) for the ABS and a bit to swap between palm and PC.
Yeah sure, lets take it offline, I opted for the Max chip because I managed to get them for free
OK, I built a 555 timer circuit… Cct diagram… I don’t have one… I just used what I had lying around… I intend to use it to drive a relay that connects the ECU pin to ground AFTER the car is running this should put the ECU int DIAG but not the disable the ABS.
Myself and John (Button Monkey) have spoken re the ABS situation and logging cables. I am happy to say that with Johns help I now have a working cable which does not dissable the ABS. This works by delaying putting the ECU into diagnostic mode by 20seconds (enough time to start the car) from the time the ignition is switched on. This delay can be changed depending on personal preference.
We are currently looking at the diagnostic plug problem as well so hopefully there might be some good news on that in the future.
Once we have more details on the ECU plug (if we can get it or not) then I’ll be offering the new type cables for sale. (For those who had the basic type from me I will discount the new one provided you return the old one)
I have done several cables for people now and the ones I am now doing have a little switch on so they can be turned off so you can leave the cable connected at all times and also when logging have ABS working. This then does not make the ECU plugs so importaint, I am still trying to find a supply of them but no luck so far. I got very close but not close enough.
As for software MMCD is free and look on the link here to check if you PDS is compatible.
I’d like you to put me down for a cable for the hp ipaq 1900 series. if you mail me your address i can send you the money or even if you have a paypal account i’ll do it that way?
my e mail is [email protected].
also where can i get this software from?
and how long does it take u to send them?
Just to clarify this cable will work with any GTO? If not which models? If it does work with all models please put me down for one of the new ones. (with the power switch and ABS reset)
