Hi I’m after some advice please… I have a mk1 Gto twin turbo… a couple of months ago my car was having trouble starting like taking a little while… anyways fast forward I put my foot down in 3rd and the car cut out… pulled over started straight up. This happened twice… my bf used it to go to work parked it up 8hrs later came out to start it and it wouldn’t start, put some fuel in thinking it had ran out and nothing.
The car cranks over but after checks it gets fuel to the fuel rail but injectors aren’t firing up and no spark… I so far have changed the cam sensor, ptu… coilpack and ecu… no luck Im just after advice on what to check now?
Any advice would be massively appreciated
As you have been here a while…
Please join full membership to post in correct technical sections.
Post locked till then, only fair on other members.
Thank you
