I’ve just bought a 1994 GTO - it’s awesome! - however it’s limited to 110mph. Does anyone know if it can be removed? I’ve been told it’s mechanical and causes engine problems if it’s removed - is this true? Thanks!
Hi @charlotte_pash
Welcome to GTOUK.
The Newbie section is used to introduce yourself and add a couple of pics of your car.
We love to see pics
To open technical info, sales and all the other sections you would need full membership.
This can be purchased from the club shop.
Jensen
Speed limiter can be removed and most members have done this.
It won’t damage the engine, but will make you smile more😉
Welcome on board do get joined, best 20 quid you can spend when you have one of these great cars, good luck with it.
Welcome to the Club, you have to show pictures, its a sort of tradition. Introduce yourself, where you’re from, etc. Pics of your car and join up, simples!!!
Welcome to GTOUK !
Isn’t that fast enough for you Charlotte, runs and hides from the fall out. Only joking, have a look through the technical section and you should find the posts about the delimiter.
Hi Charlotte,
Welcome to the club. Let’s see some pictures of your car . As said above lots of info on this so use the search function and your answer will be there.
I like to have a bit of power just for overtaking
Cheers, I’ll have a look
@andybarb brought and fitted a convertor/delimt chip recently.
He might be able to give you the details of where he got his.
That’s great, thanks!
Andy hasn’t posted for over a year mate , there is plenty on delimiters within the site in the tech sections
Good job your on the ball mate.
Jensen
Tagging members not seen for years
You could just cut pin 66 of the ecu it’s a yellow wire.
Does that work on mk2 Jerry?
@jensen360 Actually I’ll take it back I know it should work up to 1993 on imports but this is a 1994 just read it,so not sure but it’s worth a try anyway if don’t work solder it back.
Got to be worth a try as you say it can always be soldered back together. Thanks
Thanks for the welcome!
Ok, well ive literally had my GTO for just over two weeks. I actually wasnt sure what car i wanted to buy but saw the advert and, well it was love at first sight! Before the GTO i had a Jeep Wrangler that id modified for off roading, before that i had and Evo V, so i have quite a varied taste in cars! I live in a village just outside Worcester, not sure if any other members are anywhere nearby? I’ll post a pic when i figure out how to do it… ive never been on a forum before sorry!
